AlgoKP – algorithms for orthogonal knapsack problems
AlgoKP is a software to solve 2D orthogonal knapsack packing problems:
It contains an implementation of two algorithms:
- the first one uses consecutive ones matrices as main data structure: see
- Joncour, Pêcher, Consecutive Ones Matrices for Multi-dimensional Orthogonal Packing Problems, Journal of Mathematical Modelling and Algorithms
- the second one uses MPQ-trees as main data structure: see
- Joncour, Pêcher, Valicov, MPQ-trees for the orthogonal packing problem, Journal of Mathematical Modelling and Algorithms
Current developpers
- Cédric Joncour (main developper)
- Arnaud Pêcher
- Petru Valicov (main developper)
It is still beta software and is provided only for benchmarking purposes.
- the archive AlgoKP.zip (including a jar file and all benchmarks files)
Installation & Usage
A Java Virtual Machine (>=1.5) is needed to run this software.
- Installation: extract the archive (you should get the jar file AlgoKP.jar and a subdirectory benchmarksOPP/ – add your own benchmarks files in this subdirectory, if any)
- Usage: java -jar AlgoKP.jar
- “suite 1” runs the set of standard instances NGCUT, GCUT, CGCUT, OKP for the 2D-orthogonal knapsack packing problem – these files are provided for conveniency. The original benchmarks files are also available at Beasley’s OR-Library.
- “suite 2” runs the set of Clautiaux’s instances for the 2D-orthogonal packing problem – these files are provided for conveniency. The original benchmarks files are also available at Clautiaux’s Orthogonal-packing benchmarks webpage.
